Configuring the hash algorithm for a link aggregation group failed on a chip of a card.
This problem is usually due to a failure of accessing a hardware register. The hardware may be in a bad state. The error message gives the detail of the failure. The problem usually can be resolved by retrying the operation or power-cycling the switch or the card in the slot.
Error
Failed to configure the hash algorithm for link aggregation group %masterSlotPort% on slot %slot% unit %unit%: %errMsg%
| Name | Type |
| masterSlotPort | SlotPort |
| slot | Slot |
| unit | sInt32 |
| errMsg | String |
